Was wondering if I'm having an issue with Case airflow or GPU issues?
Solved by HappyGamer,
Make sure you GPU and all fans are clean and dust free, add more intake and/or let them spin faster to bring in more air.
Give them as much outside air as possible.
Yup, going to take your advice and add 2 more intake fans (both 140mm). Is it a good idea to run 3 intake fans and 1 exhaust? The 3 intake fans would be the stock 120mm that came with the case and two 140mm fans. For exhaust, I'd be using another stock 120mm. Maybe I should run the 2 stock 120mm along with one 140mm for intake fans and use one of my 140mm for an exhaust fan?
Thanks for the reply.
