Dual channel not registering
Go to solution Solved by QueenDemetria,
Hey,
I have this laptop HP 455 G3 as it only came with one stick of 8GB ram I just brought this ram to upgrade it.
CPUz is telling me that it is still running in single channel. As far as I can tell they should work in dual channel. Is there something I'm missing?  :unsure:
Thanks
Your motherboard(well, laptop) doesn't support dual channel, its listed in the specs here(sorry for the Italian link, didn't feel like changing it, but Google translate will work) : http://support.hp.com/it-it/document/c04845367
Hey,
Thanks
https://linustechtips.com/topic/535808-dual-channel-not-registering/
your laptop might not support dual channel.
running in single channel is fine
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
Well is two different manufacturers, sometimes it doesnt work.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
Hey,
Thanks
Thanks! Should of looked a bit harder before ordering!
