If anyone is still here, im looking for a similar thing but was hoping for a wireless one. Any ideas?
Main PC : CPU: I7 6700k @ 4.7GHz MOBO: Asus Maximus Hero VII RAM: 32GB Crucial 2133MHz GPU: GTX 980ti 2-Way SLI Drives: 2 850 Evo 250GB, 1 TB WD Blue CASE: 750D PSU: RM1000W
You could always get a Razer Tartarus or Orbweaver keypads and don't get distracted by the fact that they are "made for gaming" since you can really enjoy this in any context like I do with design apps. They are fully programmable with multiple keymap, unlimited macro and per-app settings.
The Orbweaver Chroma version also support per-key RGB lightning which is cool for macro identification.
The upcoming ROG Claymore Keyboard will have a detachable wireless numeric keypad that is programmable as well.
Nope, sorry, detachable =/= wireless
You could maybe hack your own keypad with a cheap number keypad (many are wireless) and few remapping software.
http://www.instructables.com/id/Making-a-powerful-programmable-keypad-for-less-tha/?ALLSTEPS
Edited by NienorGT
