I have a work pc that had 2 amd graphics cards of the same type (don't remember the model, i can find out tomorrow if needed). Each card has only two outputs. A displayport and a dvi port. Is it possible to do a eyefinity setup across 3 screens if two of the screens are plugged into one gpu, and one screen is plugged into the other gpu?
https://linustechtips.com/topic/535524-amd-eyefinity-using-2-cards/
Is this a workstation GPU, or a typical "Radeon" GPU?
I don't recall any Radeon GPU's having only one DVI, and a DisplayPort connection -- most will have at least two DVI.
If you run the two cards in Crossfire, all three displays must be connected to the primary (top) card.
If, for some reason, your two GPU's do indeed only have one DVI and one DisplayPort, you can use a MST hub on the DisplayPort connection.
The MST Hub can provide up to three (or four?) display outputs. These hubs aren't cheap though...
Club3D Mini DisplayPort to 3 DisplayPort MST Hub
http://www.amazon.com/gp/product/B00PB8FB4G/ref=pd_lpo_sbs_dp_ss_3?pf_rd_p=1944687642&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00MV55Q6U&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0ZDE921DASJ1NNDQ2NPV
Club3D Mini DisplayPort to 2 DisplayPort MST Hub
http://www.amazon.com/Club3D-Mini-DisplayPort-Multi-Display-CSV-5200/dp/B00PB8CED2/ref=pd_sim_147_1?ie=UTF8&dpID=31tkOya%2BlyL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0H5AZKX08QDXND2QWAH7
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Wait are you planning to do this at work? Or is it a work pc at home? Or I if the answer you get is the one you wanted, are you going to steal the computer from work?
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
Its a radeon 7500 series I believe.
