Posted January 27, 2016 System Specs AsRock Z97 Anniversary Edition MotherboardIntel G3258 CpuMsi Gtx 660tiEva 550 Watt psu 80 plus bronze500 gb hdd64 gb ssd boot drive Windows 8.1 proHere lately I've been getting on my computer and everything was running perfectly fine until the other day when i got on and it started doing power surges. It would come on then shut off and repeat that over and over. Somehow or another when taking it apart and putting it back together now it will come on and shut off once, then stays on afterwards with no video signal detected on screen. I have tried the usual switching out the hdmi cable, taking the card out and trying just the onboard graphics and also a spare gpu, all with the same results. No signal detected by monitor.Any help is appreciated, Thanks Eric Link to comment https://linustechtips.com/topic/535418-possible-power-supply-failure/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2016 Dead GPU? try running off your iGPU which is off your motherboard. If that works it should be your GPU problems. Magical Pineapples
