So i have the BeQuiet SilentBase 800 and just got the window sidepanel on it. Problem: It's pretty dark inside and thus it's very reflective, so i want to put some orange LED's in there to match the accents of the case.
What would be the best (not too expensive) solution here? Never bought led strips so not sure what to look for.
Thanks,
~Sam
https://linustechtips.com/topic/535170-orange-led-strips/
Thanks,
~Sam
https://www.nzxt.com/products/HUE-Plus
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/535170-orange-led-strips/#findComment-7099799
http://www.newegg.com/Product/Product.aspx?Item=N82E16811994051&cm_re=LED-_-11-994-051-_-Product
^This logisys kit will give you a nice orange, I've had this kit in the past and it's a good low cost alternative.
The hue+ is probably the most feature packed option though.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/535170-orange-led-strips/#findComment-7099882
Thanks,
~Sam
Where are you located?
We have Orange LEDs, at a great price, and many options to choose from you can find them here - http://addoncustoms.com/store/product/40-orange-led-strip-5050-tri-chip/
For that case I would recommend at least 2 LED strips.
All LEDs are wired and sleeved by hand, and tested being being dispatched. We also ship WORLDWIDE at low prices.
Any questions please ask away and we will be happy to answer. (you can also PM us)
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/535170-orange-led-strips/#findComment-7100597
Thanks,
~Sam
Welcome to the Forums!
For single color orange LED's Addoncustoms make great LED strips.
ninja'd by AddonCustoms :D
Edited by W-L
https://linustechtips.com/topic/535170-orange-led-strips/#findComment-7100618
