Is your PC using a direct connection to the router?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099470
usb or pci-e?
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099477
pci-e
http://uk.pcpartpicker.com/part/tp-link-wireless-network-card-tlwdn4800
this one is time tested and dual band as solid as it gets for wireless N cards.
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099539
I assume this will work fine in my current build until i build my new one?
PCPartPicker part list: http://uk.pcpartpicker.com/p/4jJj7P
CPU: AMD FX-8350 4.0GHz 8-Core Processor  (£137.99 @ Amazon UK)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard  (£139.98 @ Aria PC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory  (£39.30 @ Aria PC)
Storage: Corsair Neutron Series GTX 120GB 2.5" Solid State Drive  (£86.95 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.14 @ Aria PC)
Video Card: Gigabyte Radeon HD 7970 GHz Edition 3GB Video Card
Case: Corsair Vengeance C70 (Black) ATX Mid Tower Case  (£96.95 @ Amazon UK)
Power Supply: Corsair GS Series 800W 80+ Bronze Certified ATX Power Supply
Keyboard: Corsair Raptor K30 Wired Gaming Keyboard  (£39.98 @ Aria PC)
Mouse: Mad Catz R.A.T. 3 Wired Optical Mouse  (£32.99 @ Novatech)
Total: £611.28
Generated by PCPartPicker 2016-01-26 17:47 GMT+0000
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099570
Total: £611.28
yes, it will work in the new one too.
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099587
Also, do you know if the ps4 supports third part external adapters so i can use 5Ghz? I looked it up and seen things about a network bridge but i have no idea what i would get or even if they would work
no idea, don't have ps4 or 5ghz
https://linustechtips.com/topic/535136-wired-pc-adapter/#findComment-7099632
