Under what circumstances is it recommended that you use shielded Ethernet cables.
In areas where there is high amount of EM interference.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/534696-shielded-cable-question/#findComment-7094396
Shielded is best for fixed runs. Like if you build it inside a wall. They're stiffer and thicker and more fragile, that's why. Especially they shine when there are high voltage AC cables near by. Or stupid crazy stuff like radars or other pulsating electromagnetic thingimajigs.
If it's one of those STP cables with the foil on the outside(you can tell by the metal in the connector), the shielding has to be terminated into a ground preferably at both ends so it's a bad idea for like a laptop or other temporary runs.
https://linustechtips.com/topic/534696-shielded-cable-question/#findComment-7094414
oh okay thank you
https://linustechtips.com/topic/534696-shielded-cable-question/#findComment-7094429
what is that though, I googled it I just don't get it.
EM = electromagnetic
Without going to much depth about this, lets just say, there cannot be one without the other.
All electricity generates a magnetic field and all pulsating/rotating/moving magnetic fields generate electricity.
So if a magnetic field is pulsating on and off near an un-shielded cable, a current will be generated in the cable. But since there's data running in the cable, that's a really bad thing. Zero-bits are supposed to have no or very little current but if the interference is generating current in the cable, all the zeroes start to look like ones.
https://linustechtips.com/topic/534696-shielded-cable-question/#findComment-7094460
