my younger brother has a PC with a 70gb Samsung SATA hard drive in it. he has now filled the 70gb and i have got another 160gb sea-gate hard-drive but it is an IDE hard-drive, so i bought a IDE to SATA converter and installed the molex power for the hard-drive and the SATA plus the 4 pin connector on the converter. the hard-drive spins and the light on the converter comes on but the hard-drive does not show up in "My Computer" or in the "Computer Management". SOMEONE HELP ME
https://linustechtips.com/topic/534445-second-harddrive-will-not-show-up/
follow your own topics to get the notifications instantly
go to the start menu and search diskmgmt.msc. this will take you to the place were you can set up your hard drive.  here you can format it and assign a drive letter.
I swear, NO ONE in this thread read the original post.
I'd try the adapter in another computer. If you know the hard drive works, then the adapter might be faulty.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
