Right now I have been shutting down my computer using the power button in Win 8 then on my case. I make sure the monitor displays "No input Displayport" so I do not corrupt any Windows files, then use the power button on the case to turn the hardware off . But my question is, is it bad for the hardware (CPU, Mother Board, GPU) by shutting it down using the case power button.
Asus Sabertooth Z77, Intel 3770K 4.6GHz @ 1.33V, EVGA GTX670, Corsair Vengeance 16GB RAM, and Corsair 800D
https://linustechtips.com/topic/5342-using-the-case-power-button/
Sorry - not sure what the issue is. When you tell Win8 to shut down, is it not shutting down completly? I am not sure why you need to touch the power button on your case. When you tell Win8 to shut down, it shuts the system down. The only thing the system will draw at that point is a minimal trickle/standy power. typically if you then hit the power button on your case, system should boot up...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/5342-using-the-case-power-button/#findComment-61272
It should shut down just wait it might take longer for your computer to shut down. Are you pressing the shutdown button in the sidebar on the left?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/5342-using-the-case-power-button/#findComment-61290
I am shutting it down through the sidebar on the right. It then says shutting down. The monitor goes blank but the water cooler and the fans stay on. Once the monitor says No input detected I hold the case power button on the case to shut it down. I have turned off the option for the fans to stay on after the system shuts down. But is it ok to turn off the mother board, water cooler and fans using the case power button?
https://linustechtips.com/topic/5342-using-the-case-power-button/#findComment-61981
