Low point WUs?
Solved by HrutkayMods,
SOLVED IT! I had switched my card BIOSes to the OC/SLAVE bios via hardware switch to overclock more, I didn't get much more overclocking and went back to the old clocks. I left the OC BIOS on. Apparently FAH doesn't like EVGA's 960 OC BIOS, it took 2 WUs when switched back, but one card is now doing a WU 20K points higher than before, and the card that was doing 20K point WUs is currently doing a 60K WU
Apparently there is nothing wrong, there is just a lot of low point WUs right now
