Ok earlier I posted about my first idea for a pc build and edited it according to some suggestions made but no-one has commented on the changs so I thought I'd put the new build up hre and hopefully get some feedback.
My budget is around £750-800 GBP
CPU-Intel Core i5-4690K 3.5GHz Quad-Core Processor-£177.91@AmazonUK
CPU cooler-Stock cooler with CPU
Motherboard-Gigabyte GA-Z97P-D3 ATX LGA1150 Motherboard-£63.34@AmazonUK
RAM-Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory-£33.99@Ebuyer
Hard Drive-Samsung 850 EVO-Series 250GB 2.5" Solid State Drive-£61.98@Novatech
Graphics Card-Gigabyte Radeon R9 380 4GB SOC Video Card-£174.98@AmazonUK
Case-Cougar MX300 ATX Mid Tower Case-£36.44@MoreComputers
PSU-EVGA 500W 80+ Bronze Certified ATX Power Supply-£32.99@AriaPC
OS-Microsoft Windows 10 Home OEM (64-bit)-£74.84@AriaPC
Monitor-Asus VX228H 60Hz 21.5" Monitor-£108.76@AmazonUK
Keyboard-Zalman ZM-K400G Wired Gaming Keyboard-£20.50
Total-£788.81
https://linustechtips.com/topic/533828-first-pc-build/
Total-£788.81
You might want to get an aftermarket CPU cooler but that depends on if you're going to overclock or not. Also you should get a HDD because I'm pretty sure 250GB won't last you that long.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083581
I was planning on getting an external storage device,but if I didn't would it be better to get a Hybrid or a second storage device?
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083608
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£143.99 @ Novatech)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (£34.99 @ Novatech)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£61.98 @ Novatech)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  (£259.98 @ Ebuyer)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  (£41.39 @ Aria PC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£67.99 @ Amazon UK)
Monitor: Asus VX228H 60Hz 21.5" Monitor  (£109.99 @ Aria PC)
Keyboard: Logitech K120 Wired Standard Keyboard  (£13.07 @ More Computers)
Total: £832.96
Generated by PCPartPicker 2016-01-24 18:39 GMT+0000
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083629
-snip-
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£164.99 @ Ebuyer)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  (£88.88 @ More Computers)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£72.60 @ More Computers)
Video Card: MSI Radeon R9 390 8GB Video Card  (£264.99 @ Dabs)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£58.60 @ Aria PC)
Total: £830.99
Generated by PCPartPicker 2016-01-24 18:42 GMT+0000
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083652
Total: £830.99
Need OS and keyboard too, Oh and monitor
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083657
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£199.98 @ Aria PC)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  (£24.65 @ Amazon UK)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  (£87.60 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.14 @ Aria PC)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  (£50.54 @ Aria PC)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£74.99 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£12.98 @ Novatech)
Total: £820.46
Generated by PCPartPicker 2016-01-24 18:48 GMT+0000
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/533828-first-pc-build/#findComment-7083729
