Im having so much problems with my system today.
I just turned off my system to reach my bios, i ended up not being able to that as it didnt post.
When im turning on my powersupply, the "on/off" button on the motherboardn turns on and quickly turns off once again.
I had this problem 4 months ago, i ended up taking out the cmos battery and putting it on again, i wont do this once again, i want to find out whats happening.
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/
It is the pc in my signature except the 980ti,which is a 7990 atm
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7082852
Bump!
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7083217
Take every thing out of the case and re build every thing. Ifbthatbdoes not work reply back
| CPU: Core i7-4790K  |  Motherboard:  MSI Gaming Z97 GAMING 5 LGA 1150  |  CPU Cooler:  NZXT Kraken X61 |
| GPU: Single 8GB EVGA GTX 1070 FTW |  RAMCorsair Vengeance 16GB (2 x 8 GB) DDR3 1600 MHz |  CaseCorsair 330R Titanium Edition
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7086572
Before you put it back into the case, try breadboarding it. (Running it outside of the case.) This will eliminate any chance of shorts, as long as you do it on an antistatic surface such as your motherboard box.
Give an update if this doesn't fix it.
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7087122
I ended up clearing cmos, and it worked.
What would have happened if it was a short?
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7087984
Maybe it's just your cmos battery running out of power?
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7088010
Weird, the motherboard is not even 1 year old
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7088015
It wasn't a short if clearing cmos fixed it. Seems like something is wrong with your cmos or bios settings, and I don't think the cmos battery would be dying on a newer motherboard, usually they can last more than five years... You can find a CR2032 battery for pretty cheap online, to try and see if that's the problem, but it seems unlikely.
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7093344
Im working at the local "WeHaveEverything" store, so ill just pick one up there :D
Built  Not Bought
https://linustechtips.com/topic/533764-system-wont-post/#findComment-7093447
