Hello,
i am planning to build my first gaming PC but im not entirely sure if there are flaws or improvements to be made.
Please let me know if you have better ideas for the memory, storage or GPU.
here is the link to my build on PC part picker:
http://pcpartpicker.com/p/4nC7mG
thanks
PS: if you have any gaming/ relatively high refresh rate 1440p, 27" displays that are under $500 please let me know :)
https://linustechtips.com/topic/533675-advice-on-first-build-please/
I would slightly downgrade the cpu. You wont need that high of a cpu for gaming. A skylake i5 would be plenty. You could get a 390x for the money u save there.
U planning on overclocking, since u chose the k-version? The Hyper212 wont be enough for that i think.
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
Budget?
RAM is overkill. Same goes for the CPU since you're only gaming.
EDIT: My take on the build -
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($256.89 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($43.53 @ Amazon)
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($139.88 @ OutletPC)
Video Card: Sapphire Radeon R9 Fury 4GB Tri-X Video Card  ($511.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Total: $1216.14
Generated by PCPartPicker 2016-01-24 08:24 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
http://pcpartpicker.com/p/chGWNG
Try out that one. Slightly higher budget, much more power. AND you can try overclocking if you want to
As a few other people said don't bother with the i7 6700k, the only added benefit it comes with is hyperthreading and to be honest that doesn't make a whole lot of difference in most games, instead either just save a bit of money on it or use the difference in price to get another component a little better. I recently upgraded from an old AMD Phenom II x6 1090T to the i5 6600K and I Must say the difference is huge my PC is much more snappy and a noticeable FPS boost while gaming.
