Sorry for the long post, but this is a weird problem.
I bought a Core 2 Quad Q9505 (i don't have a lot of money and it was pretty cheap) to use on my MSI motherboard (G31M3-L V2)
When I powered it on for the first time, it worked fine at 2.83GHz and I ran prime95 and it was rock solid.
But a week or 2 after that it started blue screening randomly.
After another week it wouldn't even power on.
Every blue screen displayed a different error including:
MACHINE_CHECK_EXCEPTION (this is bad, right?)
DRIVER_IRQL_NOT_LESS_OR_EQUAL
(those are the ones I could remember)
I turned the CPU down to 2.5GHz and the PC booted again.
I ran memtest86 and the RAM showed no problems.
I checked for BIOS updates, and it was already up to date.
So I used it normally at 2.5GHz until recently it started crashing at that speed too.
I turned it down to 2.3GHz and now it works again.
Sorry for the lack of pictures and poor explaining, it's because I kept being... too lazy to actually take pictures and research why my PC was acting like this.
I also couldn't attach memory dumps from the crashes because I had to wipe my hard drive.
I hope it's enough info to at least get a guess about what is wrong with my computer.
And if my English is bad, sorry, I'm from Brazil.
The CPU was never overclocked.
I tried running the PC at normal speed using a Linux Live CD.
It kernel panicked, sometimes showing a MCE error.
I couldn't find any solutions on the internet, so I decided to post here.
My PC is: (don't laugh too hard guys)
Core 2 Quad Q9505
MSI G31M3-L V2
Generic DDR2 800 2x4GB
600W Satellite power supply (it does not say anything else)
Gigabyte R7 265
Kingston V300 60GB SSD
Seagate 1TB HDD
https://linustechtips.com/topic/533463-pc-does-not-boot-when-cpu-is-at-normal-speed/
Sounds like a memory controller issue or its the Quad dieing.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
It's possible prime95 has damaged your cpu/motherboard in some way, if you have another cpu you can use you could see if that's stable.
Well, I have the Core 2 Duo that came with the motherboard, a E7500, I can try running it tomorrow and see if it works.
