What kind of activity is he planning on taking part in? Casual Gaming? Hardcore Gaming? Work?
Build: i5-4460 | GT 720 | Logitech G710+ Keyboard | Corsair M65 Mouse | Dell e2314h Monitor | Windows 10
Generic Dell: Mobo, 8gb RAM, 430w PSU, 1TB Storage, XPS 8700 Case
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077240
Give me some time...
What about this: http://uk.pcpartpicker.com/p/hWqcJx
For some reason pcpartpicker wouldn't let me picka motherboard so I recommend this one:http://www.newegg.com/Product/Product.aspx?Item=N82E16813157511&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Motherboards+-+Intel-_-N82E16813157511&gclid=Cj0KEQiA5oy1BRDQh6Wd572hsfkBEiQAfdTPCvYT9ObC8BgU1R2s93WkZw1xNORik2p2UKEV6tBx0wYaAruV8P8HAQ&gclsrc=aw.ds
It would be around 610 euros
Sorry for the late reply my internet is freaking out
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077244
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077257
You can use PC partpicker Germany
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor  (€94.90 @ Caseking)
CPU Cooler: ARCTIC ACFZ13 36.4 CFM CPU Cooler  (€24.90 @ Caseking)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  (€57.90 @ Amazon Deutschland)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory  (€49.22 @ Mindfactory)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€49.99 @ Amazon Deutschland)
Case: Corsair 200R ATX Mid Tower Case  (€66.84 @ Mindfactory)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  (€63.37 @ Amazon Deutschland)
Monitor: Asus VX238H 23.0" Monitor  (€145.74 @ Amazon Deutschland)
Total: €552.86
Generated by PCPartPicker 2016-01-23 23:53 CET+0100
Buying some pieces used, like from ebay.de (http://www.ebay.de/itm/272113163778?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649) you probably can get some SSD.
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077389
For some reason pcpartpicker wouldn't let me picka motherboard so I recommend this one:http://www.newegg.co...AQ&gclsrc=aw.ds
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077394
Germany, not uk ;), thats way more than 600 euros
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077403
Hello, fellow enthusiasts! I think this would give him the most bang for his buck with upgradeability:  http://de.pcpartpicker.com/p/shz2hM   :)
The SSD and the PSU are really bad, and the iGPU from the i5 too. And the monitor is bad too :(
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077428
That CPU is going to give him bad performance for Minecraft, it's a crazy CPU intensive game.
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077466
You can do this and save up to for a R9 380.  If that is too much, the GTX 950... and if need be, a R7 370(or 260X) or GTX 750Ti:
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (€119.87 @ Mindfactory)  <<Personally, I would go with the i5 4440 instead
Motherboard: Gigabyte GA-H81M-S2H Micro ATX LGA1150 Motherboard  (€52.89 @ Amazon Deutschland)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  (€40.98 @ Amazon Deutschland)
Case: Thermaltake Versa H22 ATX Mid Tower Case  (€37.29 @ Amazon Deutschland)
Case Fan: ARCTIC Arctic F12 74.0 CFM 120mm  Fan  (€4.90 @ Caseking)  <<Front Intake
Monitor: ViewSonic VG2233SMH 60Hz 22.0" Monitor  (€135.59 @ Mindfactory)
Total: €504.88
Generated by PCPartPicker 2016-01-24 00:11 CET+0100
https://linustechtips.com/topic/533263-pc-build-for-friend/#findComment-7077542
