Watercooling Leak
By
Daanish710
in Troubleshooting
in Troubleshooting
Solved by Daanish710,
I have actually figured out that it isnt a spill. My cooler can change coulor when a dye is added. I beleive I spilt some red dye on the card when I was filling the cooler. I have ran the system for about an hour and left tissues and nothing yet.
Do you know if I can fillthe cooler because it isnt a the way to the top with fluid...
Thanks
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
