So im trying to build a moderate to high end editing computer. Something that will be able to handle a lot of programs without braking the bank.
So far this is what i have
ASUS Z170-A ATX DDR4 Motherboard Core
I5-6600K 3.50 GHz, 6 M Processor Cache 6 for LGA 1151 (BX80662I56600K)
Cooler Master case  series 5 Pro
Haven't decided on the ram or power box that ill need any suggestions ???
https://linustechtips.com/topic/532642-first-pc-build-questions/
if your doing a lot of editing your better off with a 4790k
CPU: Intel Core i7-5820K @ 4.1GHZ | MOBO: Asus Rampage Extreme V Eatx LGA2011-3 | RAM: 16.00GB DDR4 G-Skills Ripjaws @2400Mhz | GPU: 2x Gtx 980 | CASE: Cooler Master Cosmos 2 | STORAGE: 400GB INTEL 750 Series PCI-E SSD/ 3TB Western Digital WDC | PSU: Corsair AXi 1200w | DISPLAYS: ASUS PB287Q (3840x2160@60Hz) And LG27MU67 (3840x2160@60Hz)
https://linustechtips.com/topic/532642-first-pc-build-questions/#findComment-7069845
What is your budget for this build so we can better tune your build for you?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/532642-first-pc-build-questions/#findComment-7069847
If you're doing video editing, you're better off with a Xeon for the extra threads. You should go 1150 and go with Haswell. Plus Xeon's are made better than consumer i7's since they're made for servers.
ASUS Z97-E
Intel Xeon 1231-v3
G.SKILL 16GB DDR3 (you can upgrade to 32 later.)
AMD Sapphire R9 390 (better than 970 for the same price...)
XFX 850W PSU (seasonic based so it's reliable.)
Corsair 750D
Seagate 2TB HDD
Crucial 480GB SSD
I'm guessing this is about.. $1100. It's geared towards editing mostly, with a 2TB hard drive for video and an SSD for whatever else you need. Expensive and you could get away with cheaper parts, maybe like a R9 380 or R9 290. Cut a hundred bucks off the price.
Note: Xeon's are locked, so no real overclocking. But if you're a serious editor you should care more about stability than 10 seconds off render time.
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/532642-first-pc-build-questions/#findComment-7069996
