Hi all,
Im currently playing an online game right now called " Blade and Soul ".
When it comes to big group fighting/raid my FPS would drop around 10-15 and it would get really laggy for me.
I know its not my internet since outside of large group fight/raid my FPS is around 50-60.
This is my PC parts that im currently using
AMD FX8320
Cooler Master Hyper 212 evo
Gigabyte GA-990FXA-UD3
2x8 ram
840 evo SSD
1TB HDD
Sapphire Radeon R9 270x 2gb Toxic video card <--- maybe this is causing the problem for me...maybe time for an upgrade?
Pretty sure its my graphic card , if so can someone recommend me a affordable grachic card for gaming? most MMO. I dont really do anything else but game/web/movies ect.
here is the requirement for the game to run
https://support.bladeandsoul.com/hc/en-us/articles/205500389-System-Requirements
thanks
https://linustechtips.com/topic/532104-low-fpslaggy/
I don't think it's your GPU. I'm gonna just make a blind and educated guess and say that the game's optimization is shitty.
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062425
Hi all,
AMD FX8320
2x8 ram
840 evo SSD
1TB HDD
thanks
Looking at System Requirements. It cant be your GPU and I think its the game it self being badly optimised for newer parts maybe?
Your over the requirements which is good.
Wow this was old as heck, Need to update this signature!
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062440
The game is optimized well. Servers are really bad atm, it was fine when I played the first few hours it was out, but as of today I get put in 4000 man 2 hour long ques to get in and when in-game I went from 60-80 FPS to frequent drops to 10-20 FPS with my 390X. I dont think its you.
Those framerates on running on eyefinity 5760x1080 (3 monitors) at highest graphics.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062453
i think it's the combination of 3 things actually:
The game is poorly optimised
The game rely on CPU performance a lot, and strong single-core performance which your AMD FX CPU cannot deliver
Your GPU is probably a little bit under powered as well
I would suggest you monitor your GPU usage with MSI afterburner while playing the game...if your card is not reaching full utilization then it means your CPU is holding it back or the game is just poorly codded.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062571
The game is pretty poorly optimized.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062774
Hi all,
AMD FX8320
2x8 ram
840 evo SSD
1TB HDD
thanks
To be honest. I feel like your specs are preety high enough for BnS to run smoothly. your CPU is powerfull enough and GPU(you may need an upgrade but you are runnin on crossfire it shouldnt be a problem)
if you have a friend who are running a more powerfull gpu. please try them first for a raid. Changing GPUs are one of the big decision on upgrading your PC. I hope this help.
"Strive to be the best and be the best!"
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062799
good to know :) thank you
i am on GTX980M. i can play the game flawlessly on 60FPS but sometimes i notice framedrops. so i am guessing its the game.
well its impossible for me to farm faction dragon with everyone right now. When there are 40+ people are there. My fps would drop and i can't dodge , which can't do any damage and would die every other minute.
Thank you, is there a guide on using MSI afterburner? on what I should looking at and which number is right for my cpu?
Sadly i dont have any friends to test it :(
I think its the game, whenever im in combat with a group of 6 on max setting..it would drop to 20-30 fps..
https://linustechtips.com/topic/532104-low-fpslaggy/#findComment-7062855
