I'm trying to use a device that hooks in through a mic port on chrome. I got it to work in Microsoft Edge, but when I plug it into chrome, I don't get any drop down asking for permission. And when I try to use it, it doesn't work, meaning it's likely being denied permission. How can I fix this?
-GIR
https://linustechtips.com/topic/532074-chrome-problems/
chrome://settings/content
https://linustechtips.com/topic/532074-chrome-problems/#findComment-7061903
I've checked there. I've tried the mic settings several times. Any other ideas?
chrome://settings/contentExceptions#media-stream-mic
the only other thing I can think of really..
https://linustechtips.com/topic/532074-chrome-problems/#findComment-7061966
I've heard of that, but I can't find the media tab. Thanks for the help
Could try uninstalling chrome and reinstalling it, or updating it, running it in admin mode, run in compatibility mode.
https://linustechtips.com/topic/532074-chrome-problems/#findComment-7062002
I figured out it's tied to my google account. I think something might have happened, and maybe someone denied the site I want to use access to the mic on my account (As I used to share a computer) Is there any way to change this?
-GIR
https://linustechtips.com/topic/532074-chrome-problems/#findComment-7062089
