I'm really enjoying my Enthoo Luxe, but the side panels were made out of really cheap material and scratch fairly easy. I have a few somewhat noticeable scratches on the big window, and I was wondering if there is any method to repair them without replacing the window.
It's not a major issue right now, as I don't have any case lighting installed (besides a from 200 fan, but that doesn't illuminate the whole case), but I plan too in the future.
I'm just wondering if there is any sort of way to fix it, besides ordering/making a new panel.
https://linustechtips.com/topic/531941-enthoo-luxe-side-panel/
You can use something like this, to polish out the scratches, the Novus stuff is pretty good:
http://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU
Other than replacing it with something like glass which isn't as easily scratched, micro scratches and swirls will be inevitable in plastic panels from cleaning or over time.
https://linustechtips.com/topic/531941-enthoo-luxe-side-panel/#findComment-7059894
Other than replacing it with something like glass which isn't as easily scratches, micro scratches and swirls will be inevitable in plastic panels from cleaning or over time.
Yeah, those will come. These are a bit deeper though, almost like something rubbed against it.
Thanks for the info, I'll check that out.
https://linustechtips.com/topic/531941-enthoo-luxe-side-panel/#findComment-7059969
You might find this interesting.
http://mnpctech.com/#/product/648
https://linustechtips.com/topic/531941-enthoo-luxe-side-panel/#findComment-7060011
Unless they're huge gouges in the window material the Novus stuff is pretty good at removing fairly heavy scratches:
https://linustechtips.com/topic/531941-enthoo-luxe-side-panel/#findComment-7060022
