GPU temps on bad airflow case
yes you can create a custom fan curve in afterburner
once in afterburner you go to settings at the bottom, click the fan tab, enable user defined fan control, and make your curve, click ok and your done...
or you can adjust the speed at the bottom but that will lock it at that speed even in games
heres what my fan curve looks like on my 980ti so yours will be different and is just an example
post-259091-0-94696900-1453400917_thumb.
Tsubasa (The 7680x1440 beast): CPU: Intel i7 8086k | Cooler: Fully Custom Rigid Loop MOBO: Asus Z370-I ITX | GPU: Nvidia Titan Xp Star Wars | RAM: 32Gb 2x16gb Gskill Trident Z RGB | SSD: Samsung 1TB 970 Evo Nvme, 2TB Micron Sata SSD | Case: Fractal Design Nano S | PSU: Corsair SF600 With Full custom cables
you should get a better GPU....well you can use MSI afterburner i never was for silence i allways turned up my fans on max because im mostl ywearing headphones that mkaes a lots of noise itself so i was ok but you can also in MSI afterbuner can make your own fan sistem like the RP that will be set by you how its gona spin in what temps
Yeas its good idea i actually didnt do that because i like it to stay cool and i ramp it up to 100% i mean WHY NOT??? i have big headset that makes a  lot more noise when im not wearing them compared to the fan itself..... but you can make your own fan profile if you want there
Punch some holes in the case
[CPU] - Intel Core i5-4590
[Motherboard] - MSI B85-G43 GAMING
[RAM] - Kingston HyperX Beast (2x4GB) 1866Mhz... CPU only supports 1600Mhz
[SSD] - A-Data SP600 128GB SSD
[HDD]- 1Tb Seagate Barracuda
[GPU] - EVGA GTX 1060 6GB SSC
[Case] - Corsair SPEC-03 White
[PSU] - Rosewill 450W 80+Bronze
I'v got an asus r7 370 that gets 5-6 degrees more on full load than should be due bad air flow. should i use MSI after burner to make fans go faster?  74-75 degrees  gets, with MSI is 61-63.
normal fan speed is 15% with MSI is 60%
What case do you have? It might be possible to improve the airflow in your case which can have a large impact on GPU temps.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
What are your load temps?
75*C isn't horrible but you can just set fan speed to say 35% (should be quiet) and go with that
15% fan speed 74 degrees on full load
70% fan speed with MSI after burner 59 degrees on full load
Those temps are low. You're fine up to 90c at load.
85*C* - he's using a GCN 1.0 based GPU IIRC and those go up to 85*C safely only
AMD advertises the cards to be fine up until 95c.
That's for GCN 1.1. GCN 1.0 was advertised as good till 85*C safely
I don't remember 85c being advertised for their rebranded cards though.
Same core architecture so one would assume, them being cheaper, the silicon used wasn't higher grade.
OP, try with about 35% like someone mentioned. Of course you can turn the fan speed up, but that obviously makes more noise, as you probably noticed. 35% seem to be a good balance. To be honest, 75C isn't too hot at all, you can still manage it no problem and that way, the card can stay quiet.
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
Temps aren't that bad. Just set a custom fan curve in MSI AB and turn it up a bit.
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
