Ok, so here is the build.
CPU: Intel Core i7-5960x OC'ed 5.2GHz (40 PCI-E Lanes)
RAM: 128GB Corsair Dominator DDR4
GPUs: Quad SLI EVGA GTX 980Ti kingpin Edition (watercooled and in single slot brackets for low profile)
Board: ASUS X99-E WS/USB 3.1 or ASUS RAMPAGE V EXTREME
Storage: 4.0TB Intel DC P3608 PCI-E SSD (BOOT or Storage), 4x4.0TB Seagate SSHD (Backups and Storage), 1.2TB Intel 750 SSD (M.2 to SATA SSD)[bOOT]
PSU: ANY 1500-2000 Watts
The Problem is, even if Running in Quad SLI in 16x-8x-8x-8x or 8x-8x-8x-8x, does the 4.0TB Intel DC P3608 PCI-E SSD still work even if i still install this drive?
NOTE: This is just and experimental build. I know its the most expensive build. I'm only asking for some help to the problem in the build.
another NOTE: I can't afford all these stuff though. might take me a year or so to get all this.
https://linustechtips.com/topic/531731-extreme-setup-help-future-build/
My wallet just started to cry. Did anyone else have this issue?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
I bet you could make it work if you just threw some more gold bars at it. That should make it happy
And then water cool it with only the purest tears from the last albino white Panda.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
yes. i do. right now. Once i get back to my business, a multi million business that pays 10k a month, then i can afford these setup next year or this year rather. no joke about the business
Ok ill send you my address and you can send me a PC just like it LOL!
This^^, but you have to stream those tears through the ice of the rocky mountains and then take them to the top of Mt. Everest for cooling before installing.
Hey man, do still think the setup would work?
Yes i believe it would work. It would be stupid prices but you could get an Ax1500i PSU and it should run it all.
what about the PCIE SSD?
this rig will be running with 4 graphics card + the PCIE SSD
If you look at the motherboard you selected, neither of those boards will support the 4 graphics cards and an SSD. They simply do not have enough space for it.
i think they'll do. specially the X99-E WS board. and the graphics cards will be singles slots.
Oh ok sorry, i didnt realize you specified single slot brackets. Yes they will work. it might not be as fast as it could possibly go being the amount of lanes you will be using but it should be fine and run faster than any SSD would.
