Fan splitter PWM problem
I forgot to say that they are all 3 pin fans.
Ahh it makes sense now. Your fans aren't compatible with a setup like this.
3-pin and 4-pin fan control works differently.
In 3-pin fan control the controller varies the voltage it sends over pin 2 to the fan which makes it run at different speeds. 12v is full speed, so if you want 50% it sends 6v instead.
With 4-pin fan control the controller sends a constant 12v over pin 2, but sends an on/off signal over pin 4 which tuns the motor on and off at very fast speeds (think strobe light but for a motor). In this way to vary speed it changes how long the fan is on, 100% is always on whereas 50% means it is only on half the time.
You'll notice that the MB side connector that you bought only has pins 3 and 4 (speed sensor and on/off signal). It does not have pins 1 and 2 (ground, positive). This means it is getting it's power from the PSU connector instead, which is going to give you a constant 12v that you can't control. 4-pin fans would work, 3-pin fans will run but at max speed with no control.
To make this work, you need 4 pin fans. Alternatively, you could get a 3-pin splitter, but running 5 fans off one MB header may draw more power than what the MB can supply and fry the header depending on the fans.
Hope that makes sense to you.
