PROBLEMS Booting
Go to solution Solved by Alliancepotato,
I FIXED IT
It Was The GPU I Had To Re-solder It
Hi, I have A Dell XPS M1530 And I Have A Problem. Ok So Ill List The Events; I Press The Power Button, The light on the Button Stays On For About 3 Sec. The Turns Off, Fan Starts Then Stops And Hraddrive Starts And Keeps Going Trying to Read Something, Power light On Front Turns On And Stays On, But I don't see any thing on the display
https://linustechtips.com/topic/531652-problems-booting/
Does anything show up on the screen at all, like when the system posts?
Can you get into BIOS?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/531652-problems-booting/#findComment-7054332
Sounds like the issue is either the GPU or the screen.
First I would try plugging up an external monitor. if you get signs of life from the external monitor, either a connection to the built in screen is disconnected/bad or the screen is dead.
If you don't get any type of response from the external monitor, then it's likely there is a problem with the GPU which would be better as it's easier to replace.
It is also possible that something else is causing the issue.  Do you get any sound that would indicate that operating system is actually running?
https://linustechtips.com/topic/531652-problems-booting/#findComment-7056884
