for a school project I decided to make a calculator since im not too advanced in java and wanted to add sounds to the gui buttons when they are pressed I have next to no clue on how to do that and where ive looked isnt that helpful any help or pointers will be greatly appreciated. :)
https://linustechtips.com/topic/531448-java-project-inquiry/
Learning Java is a great start. Use JFrame and Map your GUI
https://linustechtips.com/topic/531448-java-project-inquiry/#findComment-7050141
