The question I always ask: what are you trying to accomplish.
If you want to cram 8 HDDs and an SSD in a case that's relatively tiny...it can't be beat.  That's why I have one.
For my compute server that doesn't have anything but a single SSD I put it in a Fractal Define Mini because I needed something that I could fit with watercooling.  Different use cases, different cases.
EDIT: (Speaking of the Define Mini...love that shit.  Can remove all of the 3.5 and 5.25 bays and have the entire front of the case wide open for whatever).
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
I just want to use it for a gaming rig. I might actually take my 3.5" out of the case if it makes too much noise under the GPU - I am thinking of removing the HDD cages and placing 2 intakes at the top in the other chamber, and using the other exhaust as an intake. This would, I believe, help with static pressure in the case as there would otherwise only be one intake in the case for the cpu and the gpu.
But I'm not sure if this would actually make that much of a difference and would in the end be a waste of time, effort and money. What do you think?
Thoughts on this Micro ATX case?
Any decent competitors?
Any competitors in what regards? Cube cases or mATX cases in general?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Cube cases.
Unless the matx tower-style case is exclusively unique and not like all the other tower cases.
Oh and it needs a window. and space for a 162~mm cpu cooler
Then the 804 is the best.
Would this cooling system be effective?
Love mine, plenty of room for high end Hardware
Oh crap that is brilliant!
What GPU is that? It has a GPU AIO cooler?
And the placement of that CPU AIO is neat!!
I might just but this case, sell my dark rock pro 3 and buy and cpu AIO
