I'm getting stuck in a boot loop that takes 2-3 restarts to get into Windows. I get Code 94 on my mobo and after removing my PCI-e wireless card, which is this TP-Link WDN4800, It boots but I'm not sure why it isn't working.
Any ideas?
http://www.amazon.com/gp/product/B007GMPZ0A?psc=1&redirect=true&ref_=oh_aui_search_detailpage
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor  ($1052.98 @ Newegg)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($121.99 @ Newegg)
Motherboard: EVGA Classified EATX LGA2011-3 Motherboard  ($403.98 @ Newegg)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($328.00 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB HYBRID Video Card  ($689.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($95.17 @ Amazon)
Total: $3594.71
Generated by PCPartPicker 2016-01-20 22:10 EST-0500
https://linustechtips.com/topic/531412-boot-issue-code-94-wireless-card-maybe/
Any ideas?
What does the boot code correspond to in your MOBO manual?
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
"PCI Bus Enumeration"
I have a HDD, SSD, M.2 drive and a 980ti. but it boots with all those things.
Check the lane assignments in the manual. Depending on where you're plugging the Wifi card into, the PCIe slot may be disabled due to M.2 being enabled. Odd quirk that comes with most X99 boards and M.2 implementation.
Yeah I've checked that and put it in an enabled slot but the wifi card literally causes my PC to not boot.
Do you have any other PCIe device that you could plug in? The card itself may be the issue. You could also try swapping the GPU to a different slot and putting the wifi card in its place.
If you can't get into the BIOS with the card plugged in there's not much troubleshooting to do aside from hardware swaps. You could try a BIOS update but that would be a last ditch effort.
If you can get into the BIOS try forcing the lane assignment on the WiFi card to match its rating (x1/x4/etc.)
