Hey guys, i have been having issues with some fans being very noisy in my new system. I have 2 140mm fans, 1 hyper 212 evo with the stock 120mm fan, and a 200mm fan, all in a Phanteks Enthoo Luxe. I have tried changing the speed in the bios and i have also tried using the fan controller that came with the case. Does anyone have any potential fixes?
https://linustechtips.com/topic/531372-fan-noise-help/
Have you identified where the noise is coming from?
Moved to Air Cooling.
https://linustechtips.com/topic/531372-fan-noise-help/#findComment-7049123
I used to have a Hyper 212 Evo and I noticed that the stock fan that comes with it is very noisy. As soon as I removed it and placed a new one, my PC was much more quieter.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/531372-fan-noise-help/#findComment-7049251
