Sonic Studio II Problems audio
Solved by SoySauce,
if you dont see any benefits in using the software why don't you uninstall it (or is it something you specifically got the mobo for?)
I cant unsintall it or cant see how to, however when I plug my headphones directly into the front I/O pannel the audio is fine but only when it is in the rear mobo panel does it have issues.
no idea why this is
very odd, I guess this is solved for the time being but thanks for your help anyway with this and replying quickly
