Good Day,
I require some help
I want to create a system where there will be a drop down list that allows selection
search
filters
and a calculation method
scenario:
I want some new Nike shoes I click on air one
I go to the box next to this I click shirt x.
prices will be listed next to the item and a calculated cost should be on the bottom somewhere
also links to buy each product from a store
End of scenario
I would also need to add many items to a certain category and require it to know the cheapest and server up that for example air one from amazon and from retailer X, retailer x has it for 50$ and amazon has it for 80$
both the items will be in the database but it should always and only serve up the cheapest and the appropriate links
I hope someone can aid me in something like this
I would like to know how I would do something like this using wordpress and what plugins coding etc. would i require
any and all help is appreciated
Thanks
https://linustechtips.com/topic/531110-help-needed/
Good Day,
I require some help
search
filters
scenario:
End of scenario
Thanks
I'm no coder, but do you guys really use -snip- oops I just mistaked the wordpress for something else xD anyway, I would've thought you would've liked to code your own website. Much more fun <3
https://linustechtips.com/topic/531110-help-needed/#findComment-7045708
Would have loved too but since I have a working website on this platform I thought i'd use it
https://linustechtips.com/topic/531110-help-needed/#findComment-7045797
Holy Crap. I go to school mate. Wish I had 14 hours and that much data. Might watch a few. If you have watched them could you please link the  most important ones
There are no corners to cut in learning to build an eCommerce site. The intelligent search alone (find the cheapest price by searching other sites)  is a several hundred man-hour project for an experienced web developer.
https://linustechtips.com/topic/531110-help-needed/#findComment-7045846
You don't need to do a marathon. The first 8 are important, the other is rinse and repeat.
Get familiar with Apache, MySQL and PHP.
Lenovo/IBM ThinkPad T61 Widescreen 15.4" 1680x1050
Intel Core2Duo T8300 2.4GHz | 3GB DDR2 from Hynix | SATA II Patched bios (Middleton) | Samsung EVO 850
Arch Linux | Linux 4.3.X x86_64
https://linustechtips.com/topic/531110-help-needed/#findComment-7045864
Well it won't be searching any sites. I thought i explained thoroughly
I will have a database of the prices at hand and will update by myself so I don't require it to search through other websites
all it Needs to do is pick the cheapest out of my database and show the appropriate links and calculate
All feedback so far is well appreciated
https://linustechtips.com/topic/531110-help-needed/#findComment-7046341
I don't quite understand the point of this project if the prices that your searching aren't going to be the current live prices at each website. Could you explain what the goal is with that?
https://linustechtips.com/topic/531110-help-needed/#findComment-7059000
But if you are going to update the database manually why don't you just have a record for each product and update that to be the cheapest one every time?
I have contacts with suppliers to provide their products and I'm not going to update every thing manually.
Which is it, are you updating the DB manually or not? Either way you are still looking at a lot more than 14 hours of work to build an eCommerce site
https://linustechtips.com/topic/531110-help-needed/#findComment-7067267
So you would like something similar to PCPartPicker, except for shoes?
That is a pretty involved project. To fill your database with the prices from other websites, you will need to scrape their data and fill it in your database. Not do it manually, that will take ages.
https://linustechtips.com/topic/531110-help-needed/#findComment-7067499
Yes Similar to PCPartPicker.
How would I go about doing this and around what would it cost to get someone to do it ?
https://linustechtips.com/topic/531110-help-needed/#findComment-7067578
What experience do you have?
At the least you will need a database to store all the data, a script to scrape websites to store prices in your database, front-end website to search the DB.
To pay someone to develop a website like that you would probably be looking at a few thousand $ at the least plus continuous maintenance from then on.
https://linustechtips.com/topic/531110-help-needed/#findComment-7068229
