You should upgrade.
Not because of the wattage, it's just that the CX series isn't the best. The EVGA G2 650W PSU would do nicely.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/530921-help/#findComment-7043340
You should upgrade.
I'm not sure, GTX 970 SLI is cutting it real close on 650 watts.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/530921-help/#findComment-7043353
You should upgrade.
Pretty sure you can find some seasonic and xfx 750 watt psus around the G2's price. Try one of those.
https://linustechtips.com/topic/530921-help/#findComment-7043358
It should be enough. Alternatively, OP could go for a EVGA B2 750W PSU for around the same price.
https://linustechtips.com/topic/530921-help/#findComment-7043383
I would play it safe get at least a 750w unit, preferably an 850w, OP might want to OC down the road.
https://linustechtips.com/topic/530921-help/#findComment-7043406
750W would be more than enough for OC 970s in SLI.
https://linustechtips.com/topic/530921-help/#findComment-7043477
Maybe I have numbers mixed up in my head and I'm recalling something else.
https://linustechtips.com/topic/530921-help/#findComment-7043545
So an 850 G2?
The EVGA Supernova 850w G2 is certainly a better, higher quality unit than the Corsair CX750M, and it's not simply because it's Gold and the CX is bronze either. If you did not have the CX750M already, I would say get the EVGA Supernova 650G2 or the 750B2 (since it's often on sale) for that system; however, that isn't the case and I would say stick with your CX750M for now rather than spending around $100 USD (not factoring rebates if there's any) or so.
If you still adamant about not sticking with the CX750M and want to get a better quality unit, then it would be helpful to know your budget and stores that you are able to buy from (link will help, as it can tell us what is available to you if you live in an unfamiliar region)
https://linustechtips.com/topic/530921-help/#findComment-7043737
My budget currently is around $150, And I would prefer newegg, but any other site would do. And I live in the U.S.
Since it price at a very good deal now, the EVGA Supernova 750 B2 is an great unit that is better build than your CX750M.
If you want a fully modular option, the 750G2 is another excellent unit, but you could save $10 if you go for the 650G2 which will power your system as well.
And here's a review: http://www.hardocp.com/article/2014/11/19/nvidia_geforce_gtx_970_sli_4k_nv_surround_review/10#.Vp-q7lLLu4w
A system with an i7 3770K OCed to 4.8GHz with two 970 in SLI during gaming loads had draw 451wAC at the wall (due to inefficiency of the PSU, the actual power draw of the components is lowered).
https://linustechtips.com/topic/530921-help/#findComment-7044116
