Get a fan head spitter olny a few bucks.
For MSI mobos you can control 4 pin to 3 pin fans.
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
https://linustechtips.com/topic/530375-fan-controller/#findComment-7035928
I have 1 4 pin connector on my mobo.
I want to control my fans but they're all 3 pin. Can I connect all of them up to a fan controller and turn down the speed of the fans using it?
However I've been told I cannot control 3 pin fans they need to be 4 pin pwm.
To control from the computer I believe that is true, but you can get external fan controllers (powered by molex, they just turn the power up and down to adjust RPM) VERY cheaply (check eBay for fan controllers). You can get ones for the front panel of the case for easy access.
 Almost as cool as my temps
https://linustechtips.com/topic/530375-fan-controller/#findComment-7035950
Could you link me a cheap one please?
https://linustechtips.com/topic/530375-fan-controller/#findComment-7035960
http://www.ebay.co.uk/itm/3-5inch-PC-HDD-CPU-4-Channel-Fan-Speed-Controller-Led-Cooling-Front-Panel-ZL-/161937889968?hash=item25b4401ab0:g:LV8AAOSwt6ZWUwRs
I bought these in bulk a while back and they work really well.
https://linustechtips.com/topic/530375-fan-controller/#findComment-7036083
Looks good. You will have to open your case to use it. Getting a direct splitter into you're mobo would allow control via software.
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/530375-fan-controller/#findComment-7036096
https://linustechtips.com/topic/530375-fan-controller/#findComment-7036098
Does it fit into a dvd bay?
It's 3.5" whereas the front panel bays are 5.25", so you could leave it with a gap, get a mounting bracket (£3?) to put them at the front, or do what I've been doing and sticking them in the HDD bays inside  :lol:
Edit: Like this http://i.imgur.com/zZuWlaL.jpg all snug with my HDD.
https://linustechtips.com/topic/530375-fan-controller/#findComment-7036111
I'm thinking of this?
https://linustechtips.com/topic/530375-fan-controller/#findComment-7036484
