usb device not recognized
Go to solution Solved by Babbleloo,
I just plugged it into my laptop to see if it was the camera but everything worked fine. Then I plugged it back into my pc and it suddenly works! Don't know what fixed it but it works now so that all that matters. Thanks to you guys for helping out
Hey there, I have a problem that I have not been able to solve by scouring through forums so I am here in hopes to get this fixed.
First: custom built pc:
Windows 10 OS
AMD Athlon 5250 quad core processor
Gigabute am1m-s2h motherboard
Asus Radeon r7 250x graphics card
600 watt corsair power supply
My problem is I have a Logitech c920 webcam that I am trying to use but whenever I plug it in it tells me "USB device not recognized... has malfunctioned". These are the steps that I have taken to try to fix this:
restart pc
check for hardware updates
uninstall driver
reinstall driver
update driver
cried a lot
From what I have gathered from the forums this should fix the problem but it hasn't for me so I am hoping that someone can help me so I can get this going. Thanks
https://linustechtips.com/topic/530315-usb-device-not-recognized/
-snip-
The most important step you can do is cry a lot. After that change USB ports. Have you tried another USB port by chance?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
Yes, I have tried all the usb ports
Are you using USB 2.0 Ports or 3.0?
It sounds like the camera has malfunctioned to me.
