Hi, whenever i play csgo, it blue screens usually in the first or second round, and it does the same thing in other games it just takes longer. Also the forum says I cannot upload .dmp files, it just says you are not permitted to upload this kind of file. also the name of the crash is "crash_csgo.exe_20160118232707_1.dmp"
https://linustechtips.com/topic/529950-csgo-crashing-and-bsoding/
Hi, whenever i play csgo, it blue screens usually in the first or second round, and it does the same thing in other games it just takes longer. Also the forum says I cannot upload .dmp files.
have you checked your temps to see if there fine ? and are you using the correct drivers ? do you have over clocks ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
Blue screens can mean a lot of things, that's why there are error codes in them.
Overheating, unstable overclock, not clean power from psu, drivers, windows fucked.
i am on a laptop hich has a usb cooler, and the codes from the bsods are as follows, sorry i forgot to mention them:driver irql not less or equal, system servce exception, bad pool caller, memory management, all sorts of different kernel related errors and page in non-paged area. I have disabled paging and done a clean install of windows 10, with all drivers up to date.
Mine usually bluescreens whenever I have Raptr on, that could be a possibility
Just throwing ideas out, I doubt that's the issue :P
I'm a fucking AMD kawaii weeaboo desu I have seen the light
i5 6600k EVGA 980 FTW Z170A PC Mate 1TB WD Blue240GB SSD Plus NZXT S340 | EVGA 600b  | Dedotated 8GB
