Stacking thermal pads?
Solved by QueenDemetria,
My dad accidentally got the 1 mm thick pads instead of the 1.5 mil, and I was wondering if it was okay to stack the pads to actually make contact with the cooler. The little black dudes are the things that are kinda nekkid.
Its fine to stack thin pads(like 1mm) a few times(like 2-3 pads), but honestly its better to just get the right thickness of pad(especially since you won't have to compress them as much in your case).
