os help
Solved by GoodBytes,
To delete windows.old folder, right-click on your c:\ drive, select properties, and click on Disk Cleanup button. Then click on "Clean up system files" button. Once it finishes its scan, in the list of items, you'll find an item "Previous Windows installation(s)", check it and click OK.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
