https://linustechtips.com/topic/528895-cheap-fan-controller/#findComment-7018125
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/528895-cheap-fan-controller/#findComment-7018127
Can I turn down the fans using this? It looks like a fan hub for me? With a fan controller can I turn down the speed of the fans?
https://linustechtips.com/topic/528895-cheap-fan-controller/#findComment-7018128
no idea, if you can't it's stupid  :lol:
https://linustechtips.com/topic/528895-cheap-fan-controller/#findComment-7018131
http://smile.amazon.com/SilverStone-Technology-All-Black-CPF04/dp/B00VNW556I/ref=sr_1_3?ie=UTF8&qid=1453040865&sr=8-3&keywords=fan+controller
Control it from your motherboard
http://smile.amazon.com/HDE%C2%AE-3-5-Panel-Speed-Controller/dp/B006UFMH3W/ref=sr_1_6?ie=UTF8&qid=1453040865&sr=8-6&keywords=fan+controller
control it manually
I've used both, both work fine. there's a cheap nzxt one (sliding controls fits in a 5.25 bay, avoid that it makes a lot of electrical noise)
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
https://linustechtips.com/topic/528895-cheap-fan-controller/#findComment-7019317
