Nope.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015594
No problemo mango chutney, it fit right in there.
I have to ask my female friends this too don't worry you not alone.
No. It won't fit. Maximum length is 11.8". No removable drive cages, either.
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015599
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015630
Can anyone reccomend r9 390 that Will fit ?
http://www.amazon.com/MSI-R9-390-GAMING-8G/dp/B00ZGF0UAE
it is 10.91 inches and the case supports 11.8. meaning it will fit in the case. ~cheers
 Pc Speck's : i7-6700K 4.0GHz , GTX 980 Ti G1 Gaming 6GB , 16 GB Corsair Vengance DDR4 - 3400 , ROG SWIFT PG278Q 144Hz , (2) Acer G277HL bid 60Hz.
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015633
Most are the same length are they not?
No. Aftermarket cooler designs can vary by 50% in length for some GPU' s like the GTX-970.
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015634
Beat you to it.  :ph34r:
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015635
Ty
Chassi:Fractal Define S Mobo:Z97 anniversary Cpu:I5-4670k@4,2 ghz Gpu:Gigabyte g1 970 Cpu Cooler:Hyper 212 evo Ram:16 gb 1600 mhz ddr3 crucial SSD:Samsung 850 evo 250gb 2x
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015650
ty i Will Go for Msi but i it's like 50$ more expensive and the Xfx is so loud luckily i sold skins on csgo
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015666
What did you sell a knife?
Need some good cash from CSGO to go buy a 390 ;)
I already had like $300 so I just needed to sell $50 to be able to afford will order it soon
https://linustechtips.com/topic/528686-will-ot-fit/#findComment-7015709
