Dual power buttons?
Solved by Stefan1024,
I was just wondering if its possible to split the 2-pin signal from the motherboard (with a cable), so I can use 2 power buttons?
Why do I want to do that?
I want to have an external power button, since the case dont sit right next to me.
Its useful during overclocking sections, where you might need to turn the PC on and off several times in a row.
The power button just shortens the two contacts as long as you press it.
Wiring up two of them in parallel is no problem. For very long cables (>10 m) you should not use the thinnest one you can finde as the resistance gets to high.
