YO YO
so i got a build im working on here http://pcpartpicker.com/p/mNn9bv
and im considering changing the cooler on there to this water cooler
http://www.coolermaster.com/cooling/nepton/nepton-280l/
first could someone tell me if this is compatible with my cpu and motherboard. Also this looks a little cheap, any other suggestions?
but my problem is that there are only 2 fan slots, which I want to use for intake, I'd make a compromise with dedicating one fan slot to this but can I mount this elsewhere?
https://linustechtips.com/topic/527404-will-it-fit-watercooling/
YO YO
Other than the front on the S340 there is not really another spot, just note that a 280mm rad most likely will not fit due to the end tanks and how the mounting points are oriented but a 240mm AIO will not have a problem.
Front Image (note it's just sideways):
http://www.pcgameware.co.uk/images/NZXT-S340-front-fan-radiator-mount.jpg
http://www.pcgameware.co.uk/reviews/cases/nzxt-s340-case-review/
https://linustechtips.com/topic/527404-will-it-fit-watercooling/#findComment-6999672
