Greetings reader,
I'm planning on upgrading or in other words replacing parts of my rig because i just damaged my MOBO(Gigabyte*something*) and CPU(AMD Phenom II X6 Processor).
I was using the CM 690 II case with Cooler Master GX650 power supply and Corsair H100 for CPU cooler and i want to continue using them.
I don't plan on changing my HDD, Optical drive, case fans or other little things.
Before we begin i need you, the reader to know that :-
*I always prefer Intel over AMD and Nvidia over ATI. I don't want to start a war, it's just my preference.BTW, i was using the above mentioned AMD processor and ATI 6850 before so i'm not being biased or anything. :)
*I don't plan on overclocking.
1. For CPU i was thinking of going with the new Skylake processor 6600 or 6600K. I'm not sure which one to go for.
2. For MOBO i was thinking of going with Gigabyte Z170 D3H because my senior colleague advised me to go for Gigabyte's 'Ultra Durable' motherboards. I want to stick around $200 or so and i'm also open for other suggestions.
-I will need 16GB DDR4 or may be more for the upgrade. But 16GB is a good start.
-In the future,not the near future, i plan on using a Nvidia Quadro card too along with a GTX for rendering purposes as i'm an architect and i also work on 3Ds and graphics. So that means i need two PCI ex slots. Not one of the strong requirements but yea, i would like that.
-I will need the motherboard to be strong and reliable for the long run.
-I'm willing to spend $200-$250 or so for the MOBO.
3. For GPU i'm confused between GTX 760 2GB and GTX 960 4GB. GTX970 or above goes above my budget. As mentioned above along with playing games i would i also like to render and work on 2D and 3D applications even before instaling the Quadro(later future add-on).
I would really appreciate you someone can help me out in my quest.
Keep it simple.
https://linustechtips.com/topic/526427-help-upgrade-guide-and-planning/
Greetings reader,
i5 6600 with a Z170 motherboard.
GTX 960 is a good start.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
If u dont plan to OC, then stick with non K processor. Also Z170 chipset is for OC, so u can buy cheaper board with no OC support :)
What about other feature and are their any other board with 2 PCIex slots and the board being reliable for the long run.
Keep it simple.
I would go for a beefier GPU and spend less on the mobo (maybe something like Gigabyte B150M-D3H). You don't need a Z170 chipset if you don't plan on overckocking anyways.
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
1. The 6600k is an overclocking processor as it has the " K " behind its name. Go for the 6600 since you are not overclocking.
2. The Z170 motherboard supports overclocking. Note that the " Z " in intel motherboards represents overclocking. Go with a H170 motherboard since you are not overclocking. If, however, you think that you will change your mind and overclock, go with the Z170 motherboard, so you only need to change the cpu to overclock.
3. Since you are doing heavy workloads with the pc, stick to 16gb of ram for now.
4. Go with the GTX 960. The 760 is getting dated.
PCPartPicker part list: http://pcpartpicker.com/p/kqVDGX
Price breakdown by merchant: http://pcpartpicker.com/p/kqVDGX/by_merchant/
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($216.95 @ SuperBiiz)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($99.99 @ Amazon)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card  ($218.98 @ Newegg)
Total: $689.91
Generated by PCPartPicker 2016-01-13 08:03 EST-0500
All the parts here are compatible with the cpu cooler, case and power supply.
Asus makes great motherboards so you should give them a shot, though the final decision is up to you.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
1 + 2. Agree with you on the Intel CPU. Sounds like you should go for a i5 6600 (non-K) and the Gigabyte mobo you suggested.
3. I know how you prefer NVIDIA over AMD, but at this price point, AMD beats NVIDIA by a solid margin with their R9 380. I'd advise you look at the benchmarks between the GTX 960 and R9 380 before making your decision.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
I dunno how it behaves with 3ds when going with amd so.. most programs perform better on CUDA than via openCL/AMD. On a gaming point, i'd go with the 380.
I'd go with the 960
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
I really feel like i should go for a reliable MOBO...
Keep it simple.
Total: $689.91
Thanks for the detailed suggestion. :)
Keep it simple.
Thanks a lot. I will look it up. How about their heat output. Keeping in mind i live in a hot climate.
Keep it simple.
I'd go with the 960
Exactly my point i can live with playing games in mid to mid/high settings but i would keep my work as my first priority. So yea... :)  960 is good for rendering and all, right?
Keep it simple.
Heat output difference is very little (about 5 degrees max).
It's also an ultra durable board from Gigabyte
http://www.gigabyte.de/products/product-page.aspx?pid=5491#ov
