Custom watercooling compatibility help
Go to solution Solved by JebKerman,
err. those look like soft tubing fittings which is why you probably haven't found anything.
you need something like these:
https://www.pccasegear.com/products/29096/ek-hdc-fitting-16mm-g1-4-black
https://www.pccasegear.com/products/29905/monsoon-hl-16-13mm-compression-fitting-matte-black
then a 16mm outer diameter tubing, (inner diameter doesn't matter)
Hi,
I was putting together a custom watercooling upgrade list for this build - http://au.pcpartpicker.com/p/K4MwRB
However while I was browsing through the tubing for the build (hard tubing), I wasn't able to find anything that fit the G1/4 fittings that I had picked - I need to know if I need to change the fittings or if I just wasn't looking hard enough for the tubing (kinda new to this stuff). Also if you could check everything is compatible and works with the above system that would be great. All prices in AUD and watercooling is very strongly prefered to come from PCCaseGear.
Here is the list: https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=538646&action=wish_lists
Thanks for any help!
https://linustechtips.com/topic/526362-custom-watercooling-compatibility-help/
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Oh ok thanks :P:D - as I said still learning haha - kind seems dumb that I didn't read into that now - thanks for the quick reply :D
