I've got 7 quick questions. Some are similar though any help is appreciated.
1. X^2=144
2. X:10 = 1000:X
Find X
3. A/B = 15/12; a+b/b = ?/12
4. 6(X+6)/15 = X-44/2
5. The second term in the proportion 5/201 = 10/402 is?
6. K+5/5(K-10) = 29/58
7. X^2 = 1936
Either I am just feeling stupid or maybe because it is late. Thanks
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/526258-help-a-fellow-techy-with-math/
ok for 1 and 7 just do the square root...  <_<
For number 2, you need to find the common denominator for both.
Your equation would be this:
x/10=1000/x. The common denominator would be 10x. Multiply both sides by 10x, and the 10 on the left cancels, and the x on the right cancels.
I can't be bothered to copy paste them all, but use wolfram-alpha for help rather then asking forum members.
Here's the first two.
http://www.wolframalpha.com/input/?i=X^2%3D144
http://www.wolframalpha.com/input/?i=X%3A10+%3D+1000%3AX
Awkward situation, this is a crossword puzzle for fudging math.  3 digit number, starts with 1 ends in 5.
I should of knew that, thanks for the refresher.
Edited by Godlygamer23
Removing double quote.
5.) Not sure what's being asked
It's simpler than it looks; I think they mean 20/804
1.) X = 12 (or -12)
2.) X = 100 (or -100)
3.) ? = 27
4.) X = 244
6.) K = 21/4
7.) x = 44 (or -44)
Thanks!
