Should I get note 5 to replace note 4?
Solved by Badgerworks,
No, you should buy a nexus 6p to replace your note 4. It's cheaper, just as good in specs, and camera. Screen is just as good, and you get stock android. I mean, maybe it's just me, but it's a lot cleaner and nicer to use than touchwiz, or whatever Samsung is calling it these days...
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3 -
8
