Air flow config?
Go to solution Solved by Oshino Shinobu,
If have 2 intake and 1 exhaust is that good?
Yes. It is called positive air pressure when you have more air being brought into the case than exhausted. As long as the intakes have dust filters, it helps prevent dust buildup in the case.
How do I know which way the air is going through my system?
I've got a corsair Spec-01 case with the installed fan (haven't touched it so its in its standard form)
I've got a hyper 212 evo with the fan attahed on the side nearest the front of the case
Finally I've got a 120mm Corsair fan at the back
https://linustechtips.com/topic/525964-air-flow-config/
If you stick your head into the case does it feel like the warm breeze of a day in the summer of 69'? If not then you probably have no airflow.
RyanTheCanadian
Network Administration / Systems Management and Security / White Hat
My computer is the definition of scrapyard wars.
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980806
There should be small arrows on the side of the fans, otherwise just drop something light by the intake and exhaust and watch were it goes.
My Build: Night Fury | i5-6600k @ 4.5Ghz | R9 390 | 850 EVO 250GB | 1TB Seagate | H230 Black
Night Theme User
         Hello Fellow Night Theme User | Why Aren't You Using Night Theme?
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980813
I've checked for the arrows
well the way the arrows point is the way the air goes. Otherwise like i said drop something.
Night Theme User
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980837
Look at the fans. The support bars will almost always be on the side that air is being exhausted. So, if you look at the fan from the side, if the support bars are on the left side, the air is going to be pulled in from the right and pushed out the left.
If you haven't moved the fans, then the intake will be at the front, and the rear fan is exhausting air out the back. The fan on the cooler should have the support bars against the cooler if it is on the side closest to the front. That way it is moving air towards the back of the case.
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980846
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980861
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980872
Yes. You usually want more intake than exhaust. It keeps the dust out if the intakes are filtered.
Night Theme User
https://linustechtips.com/topic/525964-air-flow-config/#findComment-6980876
