will all of this work ----> http://pcpartpicker.com/p/Xjnpfi am use a gtx 970 deal with it
Like doesn't work
390 is a good deal of a better card
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977579
Eh, doesn't matter. If you want to spend your money on something that performs (debatably) worse, that's your choice.
Link doesn't work either.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977610
Eh, doesn't matter. If you want to spend your money on something that performs worse, that's your choice.
The R9 390 doesn't make a huge difference in performace. In some games the R9 390 is way better and in some games the GTX 970 is better. average there is 5-10 FPS difference between the two cards but yeah I would go for the R9 390 instead because it's also cheaper.
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977618
At the 1080p yes it's not a big difference but at 1440p and 4K the R9 390 is the better choice. Plus, it's usually cheaper.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977627
yup best bang for the buck ;)
i think the only other game was shadow of mordor
and with more vram at higher res the r9 390 should be nice too, specially if you mod your games like skyrim or others
my mate got an aoc 34" 1440p display and cripples with his msi 970 on like 30fps playing witcher3
the link doesnt work @seth_yassin
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977629
That's true. It's his money so I don't care really. It's more like 1080p they're equal and 1440p is where the 390 starts to pull ahead by quite a bit.
https://linustechtips.com/topic/525724-building-my-pc/#findComment-6977630
