Have a problem and I hope I can get some help here.This is my system
Intel Core i7 4790
WD Green Desktop 1TB SATA III 3.5" Hard Drive
Board: Gigabyte B85M-DS3H-A Intel Socket 1150
Ram: HyperX FURY Red 16GB 1600MHz DDR3Gigabyte
NVIDIA GeForce GTX 660
600w PSU
CiT Galaxy Evo Gaming Black Midi Tower Case
Gigabyte GC-WB867D-I 867Mbps PCI Express WiFi
Windows 7 64bit
Here goes my problem. When I play NBA 2k15 and begin a match, it will bounce back to desktop and shows ’windows kernal driver mode stopped responding and successfully recovered‘ on the right corner. It is normal if I don't begin a match. I have checked some manuals but no clues at all. Any advice would be appreciated.
https://linustechtips.com/topic/525705-pc-problem/
It looks like a failure of the graphics driver. Make sure you have the latest graphics card drivers installed and if you are overclocking your gpu, you need to reduce the overclock a bit, as it can cause a driver failure.
i5 4690k | MSI GTX 970 Gaming 4G | Swiftech H240-X | MSI Z97s SLI Krait Edition | Corsair Vengeance Pro 8gb ( 2x4gb ) | Corsair RM750 | Samsung 850EVO 250gb SSD & WD Caviar Blue 1tb HDD | Fractal Design Define R5
https://linustechtips.com/topic/525705-pc-problem/#findComment-6977417
