I would look at remanufactured ink. I was able to get a 12 pack of ink for my Epson for $16 USD. Does the job the same as the genuine stuff and costs a ton less.
https://linustechtips.com/topic/525377-need-a-printer/#findComment-6973318
My printer has more problems than expensive ink.
CPU: i7 4790k GPU: GTX 970 RAM: 2x8GB 1866 MHz Operating System: Windows 10 64-bit Pro
https://linustechtips.com/topic/525377-need-a-printer/#findComment-6973337
What I mean't was that look for a printer that you can find remanufactured ink with. Not all of them have 3rd party ink for them. It would make your costs a lot cheaper since printers are cheap but genuine ink is expensive.
I picked up my Epson from Craigslist for $25 and my ink on Amazon for $16 so I'm set for years of printing with only $41.
https://linustechtips.com/topic/525377-need-a-printer/#findComment-6973407
