Hey guys, I finally decided to register on here after hearing Linus mention it thousands of times xD.
Anyways can a few of you guys be able to tell me if this build works. I am looking to make a simple build but not too sure.
EDIT: http://au.pcpartpicker.com/p/mqL2hM (New link)
https://linustechtips.com/topic/524998-help/
You are better off saving ~80 dollars more for the 970 version
Or you can save up to 500 to get the 980 version
Either way, that 960 may be the right thing for a semi-economy build.
EDIT: You may want to look at SSDs
They can speed up performance for OS loading times and any games and/or programs you slap on it.
DOUBLE EDIT: Salvage some case fans if the case doesn't have enough fans. Also If you plan to overclock the CPU, DO NOT USE THE NON-K VERSION. It doesn't easily overclock as you can only configure the base clock only a few 100 MHz before it gets unstable.
MULTI EDIT: If you are not going to overclock your CPU the stock cooler is more than capable for cooling the CPU. Also remember, not all GHz are the same. A 3.3 GHz Skylake i5 could theoretically beat your i3.
ULTRA EDIT: If you look on Amazon.com, you can get a VERY cheap Windows 7 Professional OEM System Builder licence. You can use Windows 7/8/8.1 keys to activate Windows 10
https://linustechtips.com/topic/524998-help/#findComment-6968872
Bit Higher end motherboard, should be a bit more stable, might OC higher, you can OC on locked CPUs now
also the 380 is a decently better choice than a 960, it looks to have better DX12/Vulkan support for the future and has more performance in general
PCPartPicker part list: http://au.pcpartpicker.com/p/mKBcJx
Price breakdown by merchant: http://au.pcpartpicker.com/p/mKBcJx/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($170.00 @ CPL Online)
Motherboard: ASRock Fatal1ty H170 Performance/D3 ATX LGA1151 Motherboard  ($149.00 @ IJK)
Memory: Kingston 8GB (1 x 8GB) DDR3-1333 Memory  ($55.00 @ IJK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ IJK)
Video Card: Asus Radeon R9 380 2GB Video Card  ($288.00 @ CPL Online)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($49.99 @ Mwave Australia)
Power Supply: Silverstone Strider Essential 500W 80+ Certified ATX Power Supply  ($58.00 @ IJK)
Total: $837.99
Generated by PCPartPicker 2016-01-11 16:37 AEDT+1100
https://linustechtips.com/topic/524998-help/#findComment-6969048
I don't plan to overclock so yeah probably won't order the cpu cooler depends tho.
Yeah I am going to order some fans maybe pull em out of an old computer.
Total: $837.99
I will look into your list not entirely a AMD fan but I could probably deal with it.
https://linustechtips.com/topic/524998-help/#findComment-6969478
I dunno man, Nvidia really seems to hate freedom
a number of games are even playable at 1440p, so you could always just use VSR to run the games higher and downsample them for your 1080p display
https://linustechtips.com/topic/524998-help/#findComment-6969614
I was going to most likely do it anyways since AMD is cheaper for some quality products. I plan to go forth with this build.
Once I have built it I plan to take photos during the build and upload it to the other forum.
https://linustechtips.com/topic/524998-help/#findComment-6969945
